martintrotter Posted April 3, 2017 Share Posted April 3, 2017 Hello, I went to a lot of videos of how to get the proper settings, and I can't do it right. I take a render with vray and other without, to show you how it's supposed to look. I'm using cinema 4d. Link to comment Share on other sites More sharing options...
Francisco Penaloza Posted April 3, 2017 Share Posted April 3, 2017 mm, more info is need it my friend, Is your material a VRay material or a regular Cinema Material?? There are transparency map?? Link to comment Share on other sites More sharing options...
martintrotter Posted April 3, 2017 Author Share Posted April 3, 2017 Regular I thing, That should be the problem!! how can I get vray materials??? Link to comment Share on other sites More sharing options...
Francisco Penaloza Posted April 4, 2017 Share Posted April 4, 2017 Well depending what version of Cinema you are using, there should be a button right in top of the material window. Also you could do right click in an empty space and choose VRay shaders and go from there. VRay still compatible with most of cinema shaders but there is always something strange with reflections or alphas. you could try to flip the map from Black to white, to white to black. But over all I would recommend to use VRay shaders. Link to comment Share on other sites More sharing options...
