Vray Fibre Optic with light spots
davewilliams
Hello all, I quite often refer to this forum for help and find it extremely useful. I now have a question which I don't seem to be able to find an answer for.
I am trying to recreate fibre optic lights that also have a 'light source' periodically throughout the fibre wire, as per this...
search?view=detailV2&ccid=cZy8LF%2fC&id=C0675A162ECF194D65CE6883079CD0374A625752&q=fibre+optic+sensory&simid=607996929060374766&selectedIndex=55&ajaxhist=0
I am modeling in 3ds max 2017 and using Vray latest version.
Any help on both modelling the random fibres and also a vray material to achieve this look? Many thanks in advance.
One way could be to model it as is, create a spline, then transform it to a tube.
Create a small sphere can could fit inside of your tube and using the spacing tool you can place all those lights along your path, then just give a glass material to your tube and self illuminated material to your lights.
If you get fancy you can use the glare effect on VRay buffer.
