Dave Buckley Posted April 12, 2017 Share Posted April 12, 2017 Does anybody know what the correlation is between a real world pc-e lens is and the physical camera perspective shift? My PC-E lens has a maximum shift of 11.5mm in both directions. Is there any way to figure out what the corresponding perspective shift percentage value would be on the max physical camera? Link to comment Share on other sites More sharing options...
Francisco Penaloza Posted April 12, 2017 Share Posted April 12, 2017 This is a though one, I think you may need to ask at Chaos group and see if Vlado setup those values as unit less or they are actual mm. I know in Cinema 4D they are mm so the camera correction should match to a similar real lens. You need to consider also if your camera is full sensor of cropped. best luck. I'll be curious when you get a more in depth answer Link to comment Share on other sites More sharing options...
Dave Buckley Posted April 12, 2017 Author Share Posted April 12, 2017 I'll post the question over there too then. I'm using a D810 with 24mm PC-E so full frame. Going from Camera to Max shouldn't be an issue as the good old 'eyeball' will get you pretty close. But If I've set up previz to mimic a 24mm pc-e then I want to be able to go straight to site and match the previz shot straight away or at least be very close to it. Link to comment Share on other sites More sharing options...
