Creating shots with objects in far distance
TomD_Arch
So I was wanting to explore creating an image based on a photograph I took of the Chicago sky line.
I started out by creating objects to scale and at real distances.
Well as soon as I adjust the vray camera's zoom or focal length to bring the distant building to the appropriate scale, the rendering hangs and crashes. I realize it may just be a memory issue because of the distances involved even with just simple objects, but really I'm curious...
How would any of you go about trying to recreate this kind of image?
No, that just puts your model out of scale and does weird stuff with the lighting set up.
rescale test 1.jpg set to feet and merged model into new scene .
If I set scene to miles and merge its so out of scale I can't even get the camera to work right.
I'm wondering if this has something to do more with the image I created with my camera is fooling me because of something like auto-focus being turned on? Like maybe the camera had to cheat this thing in order to create that image so in Max you need need to cheat your shot in a similar way?
Save
Edited by thomas.denney@gmail.com
[ATTACH=CONFIG]55412[/ATTACH] set to feet and merged model into new scene .
Save
Yea, changing system units will do that. Collapse all your geometry to editable poly and go to Utilities>More>Rescale World Units.
If your original scene was in, say meters and you adjusted units to KM, you'd scale by 1000.
Make sure everything is as close to 0 as possible before you do this. As has been said, things get far away from 0 it's gonna go to hell regardless of unit setup.
When working with large project ( Square footage not polygon) I set my scene to use Feet or Meters; not larger than that because camera setting get weird.
Having said that I don't think there is a relation of scale and crashing your scene, maybe because you are using displacement in your water?? are you??
Also remember the Light Cache can be setup as world scale or screen size. then it will affect your RAM usage.
With the latest VRay I barely use Irradiance, usually is Brute force and LC and sometimes just brute force, that way you save a lot in memory.
