Spotty and Burnt walls while rendering
raghudubey
Hello to everyone!
its my first post on this forum. I have just started learning 3d visualization and been trying out my hands on few things.
Attaching a screenshot of a render I did using Vray 3.4 and 3ds max 2017. It seems as if at places the walls are emitting light from within and other places have dark spots.
I am using a 3ds max physical camera, enabled exposure control in the camera. Have a simple vray sun in my scene. The wall and floor materials are just colors with vraymtl diffuse property.
Not sure what is going on. Have tried to play with vray sun intensity and gamma settings but no luck. Not able to find anything that works for my case. please help.
thanks
I am using GI setting as irradiance map and light cache. Earlier it was brute force i think by default
I also changed color mapping to linear multiply from the default reinhart. Rest all default. I read this somewhere on google books
Apart from that i did not change much in vray setup
Hello to everyone!
thanks
Try by First working on basic rendering set up's of V ray, then check for Indirect light illumination should be enabled. Use samplings-Primary as irradiance and secondary as light cache. These options might help you in clearing those dark spots.
this spot always come when 2 wall overlapping
i think 2 polyline overlapping in autocad and when you import in Max it extrude both together
please check max file extrude line and try to delete and check its single or double.
This worked for me. black spots and lights are gone.
Thanks Shahid and everyone for helping out!!!
