milanradulovic Posted April 19, 2017 Share Posted April 19, 2017 Hi, When I'm trying to delete one slot of multi texture, one bitmap, the 3ds max is stopping to work, and closing. Also, when I try to copy multi texture slot with more bitmaps connected, as result I have one multi texture slot with first bitmap connected and other bitmaps are disconnected. I can try to connect the rest of bitmaps, but max is crashing. Happens this to someone? Link to comment Share on other sites More sharing options...
helengarcia Posted April 20, 2017 Share Posted April 20, 2017 Try using multi sub materials option in max where we can add N-number of sub materials. You can assign separate material ID's to each sub materials and assign textures accordingly. Link to comment Share on other sites More sharing options...
helengarcia Posted April 20, 2017 Share Posted April 20, 2017 milanradulovic said: Hi, When I'm trying to delete one slot of multi texture, one bitmap, the 3ds max is stopping to work, and closing. Also, when I try to copy multi texture slot with more bitmaps connected, as result I have one multi texture slot with first bitmap connected and other bitmaps are disconnected. I can try to connect the rest of bitmaps, but max is crashing. Happens this to someone? Try using multi sub materials option in max where we can add N-number of sub materials. You can assign separate material ID's to each sub materials and assign textures accordingly. Link to comment Share on other sites More sharing options...
