chaitanyajadhav1 Posted May 4, 2017 Share Posted May 4, 2017 This might sound like strange and silly but I want to ask you guys, How to create renders like attached images. This might have answered previously. Please forgive me if it is. Link to comment Share on other sites More sharing options...
beestee Posted May 4, 2017 Share Posted May 4, 2017 The overall style in these examples is Non Photo Realisitic, or NPR. How it is accomplished depends on the software are you using. The simplest way to achieve something like this will be SketchUp. The fourth image that you attached is not axonometric, but carries the same NPR qualities of the other examples. Getting an axonometric view using your software of choice is usually pretty straightforward and located in camera or view settings of the application. Additional terms that you may need to use to find this setting are Orthographic or Parallel Projection. Link to comment Share on other sites More sharing options...
chaitanyajadhav1 Posted May 5, 2017 Author Share Posted May 5, 2017 I am using 3ds Max 2017 and V-ray 3.5. My main concern was look and feel. The reference images looks kind of vector images. Looking forward for your reply. Thanks a lot. Link to comment Share on other sites More sharing options...
Francisco Penaloza Posted May 5, 2017 Share Posted May 5, 2017 I this case Sketchup and Photoshop will be a better choice. Just export your Sketchup with white and black lines, then paint everything else in Photoshop. Link to comment Share on other sites More sharing options...
beestee Posted May 5, 2017 Share Posted May 5, 2017 I agree with Francisco that it would be better to start in SketchUp, but if you are already in Max and VRay, Vray has a Toon Effect that can create the outlines. Then you just have to get creative with the materials, which could be done by hand as Francisco suggests to give it more of an illustration look. Link to comment Share on other sites More sharing options...
chaitanyajadhav1 Posted May 6, 2017 Author Share Posted May 6, 2017 Thanks guys for your valuable suggestions. I will do it with VrayToon Effect as I am already in max and vray Link to comment Share on other sites More sharing options...
