Vray light material renders very slowly
liorsturlesi
It's most likely because you're using a value of 25,000! Why do you need it so high?? Having really bright lights and materials that are close to 100% white are both things that kill render times.
It'd be helpful to know what kind of scene you're rendering, what other lights you're using, your GI settings, camera settings etc.
I can think of two things OP might be doing:
1. Trying to ensure the linework renders as pure white; in which case the "compensate camera exposure" checkbox in the VRayLightMaterial with a 1.0 multiplier will solve the problem
2. Trying to illuminate the scene with the VRayLightMtl, in which case I would recommend adjusting camera exposure and/or using an invisible VRay Mesh Light (excluding the visible light object for shadow-casting) in conjunction with the technique in #1 for the visible light.
