lancehohip Posted May 15, 2017 Share Posted May 15, 2017 Hi there, Im seem to be having rather frustrating problems with a model drawn in revit, exported as fbx and imported as a link fbx into 3dsmax. A process I do successfully until this instance. When i load the fbx link, 3ds max changes the position of certain elements of the model. It wont allow me to move it into its correct position. Is there a reason why 3ds max should alter a revit model when importing? thank you Link to comment Share on other sites More sharing options...
Francisco Penaloza Posted May 15, 2017 Share Posted May 15, 2017 Unless you moved the model after importing, 3DMax should not change it location randomly. Maybe is a scale problem? Link to comment Share on other sites More sharing options...
lancehohip Posted May 16, 2017 Author Share Posted May 16, 2017 My point exactly Its never happened before... the item that moves is a sweep feature that is attached/linked to the wall. In revit it looks correct but in max the sweep moves away from the wall as soon as its imported Link to comment Share on other sites More sharing options...
Tom Sproule Posted May 16, 2017 Share Posted May 16, 2017 Is everything collapsed in Revit before you export it? Try that and if it still exports in the wrong place, then try resetting the xform and collapsing and export. I'm not sure how you collapse the xform in revit, but that would work in max. Link to comment Share on other sites More sharing options...
