sadiqueshaikh Posted May 19, 2017 Share Posted May 19, 2017 Hi guys, I am facing this issue from yesterday every time I hit rendder my 3ds max stopped working. Earlier the file size was 830mb because it has clothes and all mesh so I used vray proxy mesh and reduced the file size to 108mb and still it has the same issue. Please help! Link to comment Share on other sites More sharing options...
James Vella Posted May 19, 2017 Share Posted May 19, 2017 1. restart ur pc if this does not work 2. merge into a new scene if this does not work 3. report back here Link to comment Share on other sites More sharing options...
sadiqueshaikh Posted May 19, 2017 Author Share Posted May 19, 2017 not working bro Link to comment Share on other sites More sharing options...
Francisco Penaloza Posted May 19, 2017 Share Posted May 19, 2017 The actually MB size of the scene is not a direct reference to how much RAM you are using to render. Also, this will depend on the render engine you are using. Could you tell us, what render engine you are using, Version of Max, How Much RAM your machine has, are you using network or distributed rendering or just a single workstation? Type of lighting, GI, any post effect. Also, a misunderstood concept of using Proxies. A proxy only save memory while working on your file, your master scene will be lighter or small in Mb size but when rendering all that geometry is dynamically loaded anyways, if you see your proxy in the shot then all that geometry will be loaded and use RAM, as much as if it was a regular static geometry. Link to comment Share on other sites More sharing options...
