Is this a good Laptop Specification for a 5-Years Archi Course?
Please pardon me. I am extremely noob when it comes to Laptop specifications. But below is roughly what I am looking for. Is that gonna help with the course?
ASUS ROG (no idea which model too, but definitely a ASUS ROG):
- With i7-6800 / 77xx and ABOVE.
- 32GB Ram (the more the better).
- With SSD (C-Drive is in SSD).
- Graphic card Nvidia 1080.
- Screen size between 15 and 17 inches.
- Good cooling system (?)
Is the above good enough to handle ALL aspect of Rendering, Drafting, Production etc of heavy duty work from Architecture School? (Includes softwares like SketchUp, Revit, AutoCAD, ArchiCAD, 3D Max, Vray for ALL, Adobe Suite etc)... Will be using it as a workstation. Heavy Duty portable Workstation.
Will this be good enough?
Edited by izumiaiko
there is some terrific competition atm
Just be aware anything with a 1070/1080 will give you less than 2hrs battery life at capacity. There are some great ultrabooks competing against the bulky alienware/predator/rog stations atm. They are not easily upgradable, heavy (3-5kg) and battery life is extremely poor. You would be almost better off with workstation tower unless you MUST be portable (albiet not much with that thing). The other concern is they run hot, they will burn out over a 2 year period (if your lucky maybe 3 but your pushing it)
Ultrabooks for 3D
Razer
https://www2.razerzone.com/au-en/gaming-systems/razer-blade
Acer Nitro
https://www.acer.com/ac/en/US/content/series/aspirevnitro
Asus Aero 15
http://www.gigabyte.com.au/Laptop/AERO-15#kf
Dell XPS/Inspiron range
http://www.dell.com/au/business/p/laptops.aspx?c=au&l=en&s=bsd&~ck=mn
I am looking to buy a laptop and my personal opinion is with the Gigabyte Aero atm for price/power. It gives you 10hours battery life, a 1060 6GB with up to 32gb ram. Only issue is the screen is not 100% adobe (Razer comes closest with 99%), but... easy to hook up a decent monitor. The other components are a little more permanent.
Any laptop that supports 40gbps thunderbolt is a good option as you can hook up an external GPU card later on and not sacrifice the portablility/heat
Okay, I had decided on getting an ASUS ROG G752VS. Almost 99.9% confirmed. But will the ASUS ROG G752VS be a good laptop to work on renderings, heavy duty draftings etc? :D
The Specs of it is as follows:
Processor: Intel® Core ™ i7-7700HQ (6M Cache, 2.8GHz to 3.8GHz)
OS: Windows 10 Home
Chipset: Mobile Intel® CM238 Express Chipset
Memory: 16GB (8GB * 2) DDR4 2133MHz
Screen: 17.3 "LED Backlit / Slim / 300nits / Full HD (1920x1080 / 16: 9) / Anti-Glare / NTSC: 72% / IPS
Graphics: NVIDIA® GeForce® GTX1070
Storage: 256GB SSD M.2 PCIEG3x4
1TB 7200rpm SATA
Optical Unit: DVD 8X Supermulti, Double Layer [sATA]
Card Reader: SD / MMC
Camera: HD (720p)
Wireless network: 802.11ac (Dual band)
Bluetooth: 4.1
Network: 10/100/1000 Mbps
Interface4 x USB 3.0
1 x USB-C 3.1 (Gen 2) with Thunderbolt
1 x Headphone Output (S / PDIF)
1 x Microphone Input
1 x RJ45 LAN connector
1 x HDMI
1 x mini DisplayPort
1 x Power Input
Audio: Built-in Stereo Speaker Microphone
Built-in Array
Built-in
Majestic Sound subwoofer
Battery: 96Wh, 8 Cells, Lithium Ion
Power Adapter: 230W AC adapter; Output: 19.5V DC, 11.8A; Input: 100 ~ 240V AC, 50 / 60Hz universal
Dimensions: 416 x 322 x 20 ~ 49 mm
Weight: 4.3 kg (with 8 cell battery)
Edited by izumiaiko
  • 3 weeks later...
Sure you can use a laptop as workstation. Make sure it has good cooling and connect it to a monitor when you are at home.
Go to the link below and compare stuff to see how much performance difference there is and save yourself cash (just type in the thing you are looking for):
http://cpu.userbenchmark.com/Compare/Intel-Core-i3-M-370-vs-Intel-Core-i3-7100U/m259vsm176913
http://gpu.userbenchmark.com/Compare/ATI-Mobility-Radeon-HD-5470-vs-Intel-Iris-Pro-HD-5200-V1-Mobile-115-GHz/m7794vsm8009
Watch youtube or other reviews of the thing you want to buy.
