mprince Posted May 26, 2017 Share Posted May 26, 2017 The title pretty much explains it. I'm new to rendering so please excuse me if the question is trivial Link to comment Share on other sites More sharing options...
Tom Sproule Posted May 30, 2017 Share Posted May 30, 2017 Lighting is a mix of prepass and lightcache. So, you are getting a mix of both. Best would be to lower the light value slightly, also change the material on the building. It looks like it is set to white whereas you will actually want it somewhat grey to help prevent blow out. So, make it greyer until you get what you want. If you are just using the colour picker try setting the number of white at about 180 and bring it higher if needed to create a result you like. Link to comment Share on other sites More sharing options...
