miqueleu Posted May 30, 2017 Share Posted May 30, 2017 Hello , I'm working in a new render , and i have a weird effect in with the bump map, (see image) . Any clues? Thanks Link to comment Share on other sites More sharing options...
dylanlester1 Posted May 31, 2017 Share Posted May 31, 2017 miqueleu said: Hello , I'm working in a new render , and i have a weird effect in with the bump map, (see image) . Any clues? Thanks [ATTACH=CONFIG]55491[/ATTACH] Well I don't know. More info? What have you got plugged into the bump map slot?. Link to comment Share on other sites More sharing options...
Chris MacDonald Posted May 31, 2017 Share Posted May 31, 2017 Looks like you've got filtering turned off in the bump map? Link to comment Share on other sites More sharing options...
miqueleu Posted May 31, 2017 Author Share Posted May 31, 2017 I'm preforming some tests, with only the displacement map, still weird take a look at the filtering... Link to comment Share on other sites More sharing options...
Nicolai Bongard Posted May 31, 2017 Share Posted May 31, 2017 Displacement is not the same as bump. This link may be of use, obtained through the power of google: https://docs.chaosgroup.com/display/VRAY3MAX/Displacement+Modifier+%7C+VRayDisplacementMod You should not use the displacement slot in the material, but rather apply a vray displacement modifier to your object. Make sure that the object is UVWmapped correctly. Link to comment Share on other sites More sharing options...
Chris MacDonald Posted May 31, 2017 Share Posted May 31, 2017 I'm with Nicolai on this; the displacement modifier is much more powerful, though I would add using displacement on those tiles seems a touch excessive. A bump map would be far better, and more efficient. Link to comment Share on other sites More sharing options...
miqueleu Posted May 31, 2017 Author Share Posted May 31, 2017 sorry, my english its not so good..., i tryed with V-Ray Displacement Modifier, tryed putting the displace as a map in the material, and I tryed putting a bump map in the material, same results on the 3 ways... Link to comment Share on other sites More sharing options...
Chris MacDonald Posted May 31, 2017 Share Posted May 31, 2017 So what does the map look like? Link to comment Share on other sites More sharing options...
miqueleu Posted May 31, 2017 Author Share Posted May 31, 2017 Ok guys, i find the solution, I feel like a noob... i was using a JPG file, change it to a TIFF and... perfect, thanks to everyone. Link to comment Share on other sites More sharing options...
dylanlester1 Posted June 5, 2017 Share Posted June 5, 2017 Be interesting to see the quality of the Jpeg... I use Jpegs all the time for my textures with no issues Link to comment Share on other sites More sharing options...
