junekern Posted May 31, 2017 Share Posted May 31, 2017 I am attempting to create a room which is partially underground. Only trouble is, i can not work out how to clear the 'plane' out of the room without Boolean deleting the entire plane or the room itself. Does anyone know how i can solve this?? Link to comment Share on other sites More sharing options...
Michael Pickard Posted May 31, 2017 Share Posted May 31, 2017 I would personally would go into the top view and select plane and make sure it is an editable poly. I would then use the quick slice tool with snap settings set to vertex and draw the outline of the room by selecting the vertex of the room, that way you can just select the polygon and delete it. I usually do this when creating holes in ceilings or floors. Link to comment Share on other sites More sharing options...
