emmajohnson Posted June 8, 2017 Share Posted June 8, 2017 Hi, Has anyone had any luck using the particle instancer with Vray lights? If I try to place a vray light or a mesh with VrayLightMtl at each particle position, they don't appear in the render. Is this feature not supported at all? If not, any suggestions for workarounds? Thanks! Link to comment Share on other sites More sharing options...
Nicolai Bongard Posted June 9, 2017 Share Posted June 9, 2017 "The VRayInstancer plugin allows to create instances of other objects over the particles from a ParticleFlow system. The source code for the VRayInstancer plugin is included with the V-Ray SDK. In difference from Particle Flow itself, which can only work with mesh objects, the VRayInstancer can instance any renderable object, including VRayProxy, hair, displaced objects, Alembic files with other particles (through VRayProxy) etc. " - it mentions that it works with a lot of things, but it does not say that it works with lights. You should ask on the chaosgroup forums if it is possible. Link to comment Share on other sites More sharing options...
