markomarkovic Posted June 22, 2017 Share Posted June 22, 2017 Hi, First of all I want to say that i'm new in this story, i'm learning, so please forgive me if i ask some dumb questions.. I have problem, when i try to render my scene, after few seconds MAx just crashes. Every time when i try, when the message ''Preparing ray server'' apear in the message box software just close. Please, do you have idea what can be the problem? I will attach my scene, and you can try to render it, just to see what will happen. Maybe the problem is in my computer, not in the file. Regards! Radni.zip Link to comment Share on other sites More sharing options...
James Vella Posted June 23, 2017 Share Posted June 23, 2017 looks like a software issue it says you are using a student version of 3dsmax and vray2? I would contact Autodesk & Chaosgroup, check you have the latest service packs and your licences are working correctly. Link to comment Share on other sites More sharing options...
markomarkovic Posted June 24, 2017 Author Share Posted June 24, 2017 Yes, it's student version of Max, and V ray 3.00.07 I think the problem is my weak computer. Only 4GB of RAM, and dual core processor. But i'm not sure. What do you think guys? And James, thank you for answer. Regards! Link to comment Share on other sites More sharing options...
Nicolai Bongard Posted June 27, 2017 Share Posted June 27, 2017 You may want to invest in some better hardware. A quick google for the requirements led to this: https://knowledge.autodesk.com/support/3ds-max/learn-explore/caas/sfdcarticles/sfdcarticles/System-requirements-for-Autodesk-3ds-Max-and-Autodesk-3ds-Max-Design-2014.html There may be different requirements for different versions of max. Find out what version you are using and see if your computer is up for the task. Link to comment Share on other sites More sharing options...
