evanmichalski Posted July 28, 2017 Share Posted July 28, 2017 3ds max 2017 gamma input 2.2 gamma output 1.0 When trying to save the channels to a single file the gamma is outputting incorrectly with 32bit Openexr files. Now I thought I had put the wrong gamma output settings so I tested it again by saving another Openexr file but this time as an individual image channel, and made sure it was override'd the gamma and set to output 1.0 and it image came out correctly. I did another save again as an individual image channel with automatic gamma settings and it also correctly saved the image properly. This leads me to believe when saving it "all image channels as a single file" it's defaulting to a different gamma setting, but unfortunately I can't manually change the setting as the option to do so is gone. FYI, I'm using Photoshop by the way to edit these files and I have the right plugins to be able to view and display 32 bit Openexr files in case anyone is wondering. If anyone is familiar to what is going on and has an answer, I'm all ears. Thanks. Link to comment Share on other sites More sharing options...
