joaoventura Posted August 4, 2017 Share Posted August 4, 2017 Hey there Im trying to make some roofing tiles but for some reason every time I render, the displacement makes the whole surface move and i cannot figure out what is the problem thanks in advance Link to comment Share on other sites More sharing options...
jervistuazon Posted August 4, 2017 Share Posted August 4, 2017 You need a good proper displacement map, not a greyscale version of the diffusemap. Or you could try to offset it by lowering your roof, trial and error. Link to comment Share on other sites More sharing options...
SkylineArch Posted August 4, 2017 Share Posted August 4, 2017 Try adjusting the shift in the shader settings Link to comment Share on other sites More sharing options...
jervistuazon Posted August 4, 2017 Share Posted August 4, 2017 Try adjusting the shift in the shader settings A much better solution, I learned something new, thanks. Link to comment Share on other sites More sharing options...
