lstan Posted August 16, 2017 Share Posted August 16, 2017 Hi, anyone can help me, I usually render alpha in PNG using Vray Adv and the empty background will be rendered transparent, but when using Vray RT, the empty background is rendered black. I start a new empty scene and render PNG using Vray Adv and Vray RT, the same result the Adv gets alpha but NOT the RT. Why is this happening ? How to get alpha transparency in PNG using Vray RT ? Thanks for help Link to comment Share on other sites More sharing options...
Nicolai Bongard Posted August 17, 2017 Share Posted August 17, 2017 When you save as .PNG there is an option to make sure the alpha is transparent. See if that is turned off or on when you save from RT. Link to comment Share on other sites More sharing options...
lstan Posted August 17, 2017 Author Share Posted August 17, 2017 Thanks Nikolai i contacted Chaos Group, it seemed Vray RT 3.0 and below dont support PNG alpha Link to comment Share on other sites More sharing options...
notamondayfan Posted August 21, 2017 Share Posted August 21, 2017 I would render the RGB and alpha pass separately, then use Photoshop (or similar) to add the transparency, and save out as a png. I would never render directly to a png file. Link to comment Share on other sites More sharing options...
