hj Posted August 17, 2017 Share Posted August 17, 2017 Hello, I would like to ask you, how it is possible to make wallpapers, cushions or pillows with metallic effect? I attached some pictures, when I have one texture projected on the curtain, I would like to have only patterns gold. I am new to Vray, if I would know at least how its called, I would find some tutorial.. Please help me, THANK YOU SO MUCH! Link to comment Share on other sites More sharing options...
Casey Hawley Posted August 17, 2017 Share Posted August 17, 2017 Easily done for reflection with a Mix shader using black and white mask/alpha image. For different colors, again a Mix shader in diffuse with the mask/alpha pattern. Use another Mix in the bump for different surfaces/patterns. Are you seeing a pattern yet? Yes, another Mix shader for opacity/transparency if needed. Link to comment Share on other sites More sharing options...
Nicolai Bongard Posted August 18, 2017 Share Posted August 18, 2017 Also, if you prefer, you can create one wallpaper material and one gold material, then blend them in a vrayblend material. Link to comment Share on other sites More sharing options...
hj Posted August 18, 2017 Author Share Posted August 18, 2017 Thank you, I ll try it like this Link to comment Share on other sites More sharing options...
