qendrimhusaj Posted August 22, 2017 Share Posted August 22, 2017 Hello, I'm working on a new product in 3ds max and I'm stucked in this led light . Is there anybody who can help me how to achieve the lights like in image attached? I use v-ray All the best, Qendrim Link to comment Share on other sites More sharing options...
Francisco Penaloza Posted August 24, 2017 Share Posted August 24, 2017 Just model the whole thing as it is in real life, V Ray will reproduce the lighting correctly. Remember that all those surface are not perfectly flat, so try to add some soft bump or distortion to the mesh it self so all those reflections are not perfect mirror as they would if you just do a fast modeling and shading. Link to comment Share on other sites More sharing options...
qendrimhusaj Posted August 25, 2017 Author Share Posted August 25, 2017 But I have the problem with the lights inside ,I don't know what type of light to use to achieve this but I don't get a good results,I use metal material for inside maybe I'm wrong with this ,Should I use other type of material inside ? Link to comment Share on other sites More sharing options...
Francisco Penaloza Posted August 25, 2017 Share Posted August 25, 2017 I think a chrome like material should do, most of those plastic devices like lamp use a chrome looking material to reflect light. Without knowing much of the shape of that object I created something similar, with a shiny plastic outside and a chrome material on the inside. then placed two VRay lights tinted purple color/bluish. then just enhance with glow and glare effect. Link to comment Share on other sites More sharing options...
qendrimhusaj Posted August 25, 2017 Author Share Posted August 25, 2017 Thank you very Much Francisco, Can I ask you if you can send me the 3d file and I will modify some changes on it because I think this are what I'm looking Link to comment Share on other sites More sharing options...
qendrimhusaj Posted August 25, 2017 Author Share Posted August 25, 2017 Or can I send you my 3d model ? Link to comment Share on other sites More sharing options...
olhorobot Posted September 6, 2017 Share Posted September 6, 2017 the problem is that that device uses ultraviolet light in real life, right? Link to comment Share on other sites More sharing options...
qendrimhusaj Posted September 10, 2017 Author Share Posted September 10, 2017 the problem is that that device uses ultraviolet light in real life, right? Yes the problem is that light . I don't know how to get it in v-ray . Can you help me ? Link to comment Share on other sites More sharing options...
