maryamz Posted September 3, 2017 Share Posted September 3, 2017 Hello everyone ive just started to learn 3dmax. first i tried to work on max 2017 but the snaps didnt work well and i didnt know how to fix it. so i moved to max 2016 and now when i hover my mouse over the icons of menus and panels the name doesnt appear :/ its too difficult to continue like that for me specially coz im new to this software. has anyone had same problem as mine ? or think can help me ? id be thankful Link to comment Share on other sites More sharing options...
Sketchrender Posted September 3, 2017 Share Posted September 3, 2017 No It sounds like your out of memory, What spec is your machine and is it up to it ? The snaps work fine. For basic modeling in plan use the 2.5 snap. phil Link to comment Share on other sites More sharing options...
maryamz Posted September 7, 2017 Author Share Posted September 7, 2017 Hello phil thanks for the answer ; my system attributes are : Intel® Core™ i7 6700HQ Processor, Intel® HM170 Chipset 1TB HDD 5400 RPM NVIDIA® GeForce® GTX 950M with 2GB/4GB DDR3 VRAM Graphic DDR3 Link to comment Share on other sites More sharing options...
maryamz Posted September 7, 2017 Author Share Posted September 7, 2017 For basic modeling in plan use the 2.5 snap === > i didnt understand that ; whats the 2.5 snap these are my system attributes : Intel® Core™ i7 6700HQ Processor Intel® HM170 Chipset 1TB HDD 5400 RPM NVIDIA® GeForce® GTX 950M with 2GB/4GB DDR3 VRAM Graphic DDR3 Thanks in advance Link to comment Share on other sites More sharing options...
James Vella Posted September 20, 2017 Share Posted September 20, 2017 (edited) 2.5 snaps to 2D views 3 snaps to 3D views I dont recommend using 3 when modelling from CAD, you can screw up your Z heights (sometimes they are too subtle to notice until its too late). 3 is great for quick snapping geometry to geometry. Both software snapping works fine for me (2016/2017). Ensure you have the latest service packs. If your having graphics issues (icons/names not appearing) try update your drivers to see if that resolves the problem. edit: 4GB of Ram seems quite low, maybe Phil is correct. Edited September 20, 2017 by redvella Link to comment Share on other sites More sharing options...
maryamz Posted September 29, 2017 Author Share Posted September 29, 2017 thank you James ; i updated drivers but still having same problems in both versions i dont really know what else to do coz i dont know what's causing this problem. it isnt even an old system Link to comment Share on other sites More sharing options...
James Vella Posted September 29, 2017 Share Posted September 29, 2017 Do you have 4GB of RAM? Seems extremely low for 3dsmax, the recommended is 8gb (even though it says 4gb as a minimum, with system resources running you would barely be able to render a scene with that much ram). I wouldn't even recommend lower than 16GB to be honest, and for archviz minimum 32GB. https://knowledge.autodesk.com/support/3ds-max/learn-explore/caas/sfdcarticles/sfdcarticles/System-requirements-for-Autodesk-3ds-Max-2016.html Link to comment Share on other sites More sharing options...
maryamz Posted September 29, 2017 Author Share Posted September 29, 2017 my system RAM is 8 GB DDR4 . 4GB is for VRAM of my Graphic Link to comment Share on other sites More sharing options...
James Vella Posted September 30, 2017 Share Posted September 30, 2017 Something certainly doesn't sound right then. Have you tried to switch from Nitrous to Direct 3D? Failing that I would do things in this order: 1. Use Driversweep and remove your drivers completely for the video card 2. Reinstall the latest drivers 3. Uninstall all 3dsmax versions 4. Reinstall 3dsmax (only the version you intend on using) Link to comment Share on other sites More sharing options...
maryamz Posted September 30, 2017 Author Share Posted September 30, 2017 Thank you James Vella; I will try it and then let you know what happens hope it works Link to comment Share on other sites More sharing options...
James Vella Posted September 30, 2017 Share Posted September 30, 2017 by the way, I should clarify. try the driver sweep and reinstall drivers first. If that fails, then reinstall 3dsmax. Link to comment Share on other sites More sharing options...
