jasminyes Posted September 9, 2017 Share Posted September 9, 2017 hey guys, I have a huge problem with the lighting and am unable to solve it for a while now. I use cinema r18 and vray 3.4 . No matter what I do it just looks unrealistic. The materials look flat, even though there is nothing wrong with them. I use a simple sunny hdri from peter guthrie, adjusted exposure and rgb color profile, gamma value of 0,7-0,8. Any help is much appreciated. Link to comment Share on other sites More sharing options...
Devin Johnston Posted September 11, 2017 Share Posted September 11, 2017 Your problem is that you don't have a complete scene, you can't expect an architectural scene to look real if you have no environment. Link to comment Share on other sites More sharing options...
Marco Manunta Posted September 11, 2017 Share Posted September 11, 2017 yes definitely true what Devin said...is it realistic that situation ? the height of the point of view ? did you've ever seen something like this in the real world ? i don't think so. First start by adding some context, and you will see that the light will appear much more realistic.. Link to comment Share on other sites More sharing options...
SkylineArch Posted September 12, 2017 Share Posted September 12, 2017 Your materials look flat as well. Remember, Link to comment Share on other sites More sharing options...
jasminyes Posted September 12, 2017 Author Share Posted September 12, 2017 Thank you all!!! I'll look at the fresnel thanks , and since I have a new vray version I had AO switched off. I changed materials and now it looks much better. And yes, I have taken away the grass because for test renderings like this it would take too long. Link to comment Share on other sites More sharing options...
Chris MacDonald Posted September 19, 2017 Share Posted September 19, 2017 jasminyes said: since I have a new vray version I had AO switched off. It should be. AO is out-dated and ugly, aside from in very specific situations. Link to comment Share on other sites More sharing options...
