chrisjohnson2 Posted September 12, 2017 Share Posted September 12, 2017 Hello guys, I am facing an unusual problem during my rendering with vray 3.4 for max 2017. My render always brings up an incredible amount of noise at the end but Only when bitmap materials are in the scene even with vry high global dmc and irrediance map. As you can see on the picture, the geometry that has the default material does not produce noise. Do you have any idea about why this is happening? Link to comment Share on other sites More sharing options...
Nicolai Bongard Posted September 12, 2017 Share Posted September 12, 2017 Noone will have any idea whats going on unless you post your render settings. The standard advice is read the manual and just use one of the render presets and you should be good to go. Link to comment Share on other sites More sharing options...
notamondayfan Posted September 14, 2017 Share Posted September 14, 2017 I would hazard a guess that you have a Vray plane light intersecting some geometry. Link to comment Share on other sites More sharing options...
Tom Sproule Posted September 17, 2017 Share Posted September 17, 2017 Noone will have any idea whats going on unless you post your render settings. I agree! Please post your render settings! Link to comment Share on other sites More sharing options...
