xjapanese Posted September 20, 2017 Share Posted September 20, 2017 (edited) Hi Guys, Any recommendations for motherboard with regards of bios issues. What cooling solution do you recomend for a reasonable overclock. Thanks Edited September 20, 2017 by xjapanese Link to comment Share on other sites More sharing options...
beestee Posted September 20, 2017 Share Posted September 20, 2017 We are preparing to build a 1950x. We are seriously considering the ASUS ROG Zenith Extreme sTR4, but it looks to be having some early adopter problems as you mentioned. What appeals to me most with that one in particular is the DIM2 dual PCIe x4 module that will accept NVMe SSDs, just hope they get the RAID and BIOS issues worked out soon. We have not used ASRock before, but it seems to be performing better in customer reviews. Link to comment Share on other sites More sharing options...
xjapanese Posted September 21, 2017 Author Share Posted September 21, 2017 THanks Benjamin.I guess will wait for a while too. Link to comment Share on other sites More sharing options...
simonoudiette Posted October 2, 2017 Share Posted October 2, 2017 Hi Nikolay, I'm currently building a new rig myself although I won't go as far as a threadripper. I've read good comments regarding the Asus Crosshair VI Hero. No BIOS issues and quite easy to overclock your CPU with it (managed to get a 1800X to 4,1Ghz without any problem from what I read). Regarding cooling solution, really depends on your case, and what you're aiming for in terms of noise. Watercooling system are now quite cheap an efficient (see Cooler Master Master Liquid 240 for example). Most of the good cases come with 140mm fans which can do the trick. Hope that helps! Link to comment Share on other sites More sharing options...
beestee Posted October 4, 2017 Share Posted October 4, 2017 So we ordered the parts to build at the end of last week and the last of them finally arrived yesterday morning. Got it all put together and it is now up and running. ASUS Zenith Extreme mobo Ryzen Threadripper 1950X processor 128 GB GSkill TridentZ ram 1TB Samsung 960 Evo PCIe ssd Aorus GTX 1080Ti 11GB graphics card Watercooled CPU and GPU Still need to get all the software installed and do some tests for OC stability, but once it was all together it fired right up, even did some overclocking on it's own. Photo: https://1drv.ms/i/s!AotCHBBj6ZsypnbSkJuerN9yULRf Link to comment Share on other sites More sharing options...
Graphite Posted November 15, 2017 Share Posted November 15, 2017 How did this build turn out? Link to comment Share on other sites More sharing options...
beestee Posted November 15, 2017 Share Posted November 15, 2017 Took a little while to get some bugs worked out, but it is performing well now. As expected it renders a little over twice as fast as a Ryzen 1700 8-core that I am using as a workstation. Link to comment Share on other sites More sharing options...
Graphite Posted November 16, 2017 Share Posted November 16, 2017 Nice; good to know. My rig is due for an update and Threadripper makes me want to switch to an AMD chipset. Link to comment Share on other sites More sharing options...
Stephen Thomas Posted November 17, 2017 Share Posted November 17, 2017 The 5-way optimisation tool for overclocking is one reason I would always go for an Asus board. A great little tool! Link to comment Share on other sites More sharing options...
