ioanadanciu Posted October 7, 2017 Share Posted October 7, 2017 hello guys.I m using vray 3.20.02 for max 2016. I am actually a rendering beginner and i have some troubles... I made my render setup as you can see in those pics,but when i render,the rendering tab is white...or black... also,on the screen(while rendering) is shown up a VRAY MESSAGE TAB...which is sending the warning: Subpixel color is on:render results may have incorrect brightness did this ever happen to anyone? Link to comment Share on other sites More sharing options...
Justin Hunt Posted October 11, 2017 Share Posted October 11, 2017 you can ignore the subpixel message, it useful for cleaning up jaggies around super bright areas, Default is OFF you have "Show Alpha" ticked on The white ball next to the RGB buttons Link to comment Share on other sites More sharing options...
Chris MacDonald Posted October 11, 2017 Share Posted October 11, 2017 It's a common error, and the effect it has on your render will be visible; however it's up to you to decide whether it's worth it or not. As justin said, it has its uses from time to time. I personally have it always off. Peter guthrie did some comparisons. http://www.peterguthrie.net/blog/2012/07/rendering-oof-highlights Link to comment Share on other sites More sharing options...
