sophiemil Posted October 12, 2017 Share Posted October 12, 2017 Hello, I`m new here. To be honest, I regisetred because I need help from someone who knows vray and max a way better than me I am an amateur, but I`m still learning and trying. Here`s the problem.. This is my mat editor (http://prntscr.com/gwl0mo)- notice how dark materials are. It`s because they appear really light in my scene and too saturated. I `d like to avoid that. I thought it`s gamma, but I dont know what it is anymore. Settings vray--->http://prntscr.com/gwl1ov settings max --->http://prntscr.com/gwl1vy output gamma is set to 1.0 In vray render window sRGB is off. This is the same color-----> http://prntscr.com/gwl41f Thank you so much in advance Link to comment Share on other sites More sharing options...
tonyroebuck Posted November 7, 2017 Share Posted November 7, 2017 I think maybe your burn value is too high. It could also be that your materials are too reflective if they appear light... Link to comment Share on other sites More sharing options...
Chris MacDonald Posted November 8, 2017 Share Posted November 8, 2017 sRGB should be on in the VRay frame buffer. To be honest, all the default settings straight out of the box should work fine. Link to comment Share on other sites More sharing options...
Guest fractalcgi Posted November 8, 2017 Share Posted November 8, 2017 Adding to the reflectivity comment, I would have thought that the high Fresnel IOR will be causing it to look so bright/metallic. Could be worth colour correcting the reflection map too. Fractal CGI Team http://fractalcgi.com Link to comment Share on other sites More sharing options...
