jorgesanchez1 Posted October 28, 2017 Share Posted October 28, 2017 I tried moving the pivot to the polar array center but it does not work. Please HELP! I have 1,340 seats and I don't want to copy rotate all of them by hand. Thank you. Link to comment Share on other sites More sharing options...
heni30 Posted October 28, 2017 Share Posted October 28, 2017 (edited) I would attach them to a simple geometric object like a disk that is right below them. That way the center will be the center of the disk and everything will rotate properly. Then just delete the disk. Edited October 28, 2017 by heni30 Link to comment Share on other sites More sharing options...
jorgesanchez1 Posted October 28, 2017 Author Share Posted October 28, 2017 The problem is that they all have to be mixed ppl men, women, etc and if I attach a disc to one and array it, it will then be the same person arrayed. I can however array the ppl and I get a good mix. It's only when I shift the pivot of the seated person to array the ppl about the correct arc point when it gets all gets messed up and the ppl all regenerate at the pivot instead of landing on their seats. I think the solution lies in rotating all ppl at same time once they are created so that one pivot axis looks at the arc pivot center point. PLEASE HELP! Link to comment Share on other sites More sharing options...
jackbird Posted October 31, 2017 Share Posted October 31, 2017 * Create a point helper at the center of your arc * Set the Reference Coordinate System dropdown to Pick... and choose the point helper * Set the Center flyout button to Use Transfomr Coordinate Center Now the Array tool will array in an arc exactly the way you want: Link to comment Share on other sites More sharing options...
jorgesanchez1 Posted October 31, 2017 Author Share Posted October 31, 2017 Thank you John Seagull, now if we could only figure out how to array a mix of men and women instead of the same sex. Don't know how to do it. I tried doing as a copy and as an instance but it only copies the same sex I start the array with. Either all male or all female. Anyway I ended up doing it by hand and using the align tool. Here it is. Link to comment Share on other sites More sharing options...
heni30 Posted October 31, 2017 Share Posted October 31, 2017 Looks great. I like the variety of people types and poses. Looks like a natural mix of folks. You could array a mix of male/female - Array a group of 8-12 people at a time - then subtract people here and there and change some colors to make it less uniform. Link to comment Share on other sites More sharing options...
Chris MacDonald Posted October 31, 2017 Share Posted October 31, 2017 Might wanna check that spelling of "Centre" above the stage. Link to comment Share on other sites More sharing options...
jackbird Posted October 31, 2017 Share Posted October 31, 2017 select all chairs, and type in the maxscript listener: for obj in selection do obj.gender = (random 0 1) and hit numpad enter. Link to comment Share on other sites More sharing options...
jorgesanchez1 Posted October 31, 2017 Author Share Posted October 31, 2017 Thanks Chris! Link to comment Share on other sites More sharing options...
jorgesanchez1 Posted October 31, 2017 Author Share Posted October 31, 2017 Thanks Jon Link to comment Share on other sites More sharing options...
