material not showing in render
prithwirajgopi
hi guys,
please help me out..
I have created an object using line (extrude) and then applied a material but it is not showing in view port or in render.
but when I am using this material on a box or any other pre-set objects its showing and rendering. ? ( I m using v-ray for the material application )
what could be the problem. Am I doing something wrong here ?
please help me out. (please refer the pic )
regards
When this happens to me it's usually because of a mismatch between texture and uv settings on real world scale.
Usually what happens is the texture is very very small so it renders as the average color - so that's a good way to check. If your texture is dirt and the render is bright magenta, it's probably a different problem.
