oliviuvais Posted November 7, 2017 Share Posted November 7, 2017 Hi. I have a problem with V-Ray rendering, i get light in every render with no lights in my scene. I have found that turning of the Maps in V-Ray render settings gets me rid of the light. This also occurs if i create a new, empty scene, so it must be some screwed render setting. Any ideea? Link to comment Share on other sites More sharing options...
Nicolai Bongard Posted November 7, 2017 Share Posted November 7, 2017 Perhaps this is the issue? https://docs.chaosgroup.com/display/VRAY3MAX/Global+Switches Lights – Enables or disables lights globally. Note that if you disable this option, V-Ray will use default lights unless Default lights is set to Off. Hidden lights – Enables or disables the usage of hidden lights. When this option is enabled, lights are rendered regardless of whether they are hidden or not. When this option is disabled, any lights that are hidden for any reason (either explicitly or by type) will not be included in the rendering. Link to comment Share on other sites More sharing options...
oliviuvais Posted November 7, 2017 Author Share Posted November 7, 2017 Ty so much. That fixed it. You saved me TY Link to comment Share on other sites More sharing options...
