lucalanceri Posted November 8, 2017 Share Posted November 8, 2017 As title, when i try to use a displacement map on my models i obtein a real hugly noise effect, it seems related to the edge lenght set, lower it is, more noise is generated, if i unchek view-dependent box the effect seems go better but not actualy disappears. Here a picture of the issue. Someone had the same problem? Sorry for my broken english Link to comment Share on other sites More sharing options...
Francisco Penaloza Posted November 8, 2017 Share Posted November 8, 2017 Vray displacement is very dependent on the triangulation of the geometry. In your case, you could use a smooth modifier before you place your VRay Displacement Modifier. Also be sure your displacement map is good quality, about 2k Should do. Now, for that type of detail on characters, I would recommend using a normal map instead displacement. Link to comment Share on other sites More sharing options...
SkylineArch Posted November 9, 2017 Share Posted November 9, 2017 Vray displacement is very dependent on the triangulation of the geometry. In your case, you could use a smooth modifier before you place your VRay Displacement Modifier. I use the subdivide modifier... probably the same end results. (assuming we are talking about Max) Link to comment Share on other sites More sharing options...
lucalanceri Posted November 9, 2017 Author Share Posted November 9, 2017 Vray displacement is very dependent on the triangulation of the geometry. In your case, you could use a smooth modifier before you place your VRay Displacement Modifier. Also be sure your displacement map is good quality, about 2k Should do. Now, for that type of detail on characters, I would recommend using a normal map instead displacement. Congratulations Nothing of what you say fit whit my question. I now that's very dependt by triangulation, the problem is that more accurate is the edge lenght more is the "noise" and, how you can see by the picture, it's a very weird kind of noise, don't seems the regular noise by low subdivisions. Attach a more High Resolution image. [ATTACH=CONFIG]55917[/ATTACH] All map are in 8k Link to comment Share on other sites More sharing options...
Chris MacDonald Posted November 9, 2017 Share Posted November 9, 2017 Congratulations Nothing of what you say fit whit my question. If you wanna be a **** to someone trying to help you, don't expect help. It's not his fault you don't know what you're doing. Link to comment Share on other sites More sharing options...
lucalanceri Posted November 9, 2017 Author Share Posted November 9, 2017 Simply tired about people that every time you made a question they give the answer not for help but just for saying something. It's not helping it's ego. If i hade one penny for every people that answer about a displacement map issue with "use a normal" map i will be ****ing rich for the god sake! You have the answer? Tell it. You don't have it? Tell nothing. I don't think to ask to much Link to comment Share on other sites More sharing options...
Chris MacDonald Posted November 9, 2017 Share Posted November 9, 2017 You have the answer? You will never know. Link to comment Share on other sites More sharing options...
Francisco Penaloza Posted November 9, 2017 Share Posted November 9, 2017 Simply tired about people that every time you made a question they give the answer not for help but just for saying something. It's not helping it's ego. If i hade one penny for every people that answer about a displacement map issue with "use a normal" map i will be ****ing rich for the god sake! You have the answer? Tell it. You don't have it? Tell nothing. I don't think to ask to much Dude you need to calm down, first, learn how to talk in a professional environment will help you to grow as a person otherwise nobody will ever help you or even consider you to work with. This is not a kiddy fan website full of fanboys trying to see who has the bigger D#!ick. Besides is everybody if telling you to use a normal map instead of displacement, well maybe they are into something. Link to comment Share on other sites More sharing options...
lucalanceri Posted November 9, 2017 Author Share Posted November 9, 2017 Yes and exactly what i suppose to do with this advice if i need to use a displacement map? Better idea, why thay cannot simple put away displacement tools from 3ds for good? Maybe, just maybe, it's because displacement it's usefull for something? Yeah i know professional environement, and yet, if someone come to my studio asking something and i answer with something else not related and i waste time of studio they fire me. Beside, i'm perfectly calm, but you cannot avoid sarcasm when they answer to you in this way Link to comment Share on other sites More sharing options...
