Guess Lens Shift How to turn it off?
ishmaeladams
  • 8 months later...
Hi,
Don't you hate it when someone does not know how to do something and responds anyways? Well, I guess he was just trying to help.
When you hit Guess Lens shift. Your asking Rhino to - well, take a guess. Sometimes its right and others way off. Attached is a screenshot on how/where to fix it.
Go to your settings in Rhino Camera/ Effects / Vertical Tilt. Here you will see some high number. Just click on the number and reset it back to zero. Normally this number would be around .1ish or .0ish. Change your setting to a test render and use the RT and play with these numbers to get the feel you're looking for in real time.
Hope that helps.
Hi Ishmael,
You need to go to the Chaos Group website and have a look on how to turn it on and off.
Here's the website link:
https://docs.chaosgroup.com/display/VRAYRHINO/V-Ray+Menu#V-RayMenu-Overview
Best, Tom
