gianzanare Posted November 15, 2017 Share Posted November 15, 2017 Hello, I'm test rendering a scene in 3ds max with vray, and I have an HDRI image set in the background, and in a vray dome light, but when the render finalizes the background is grey and weird, and no HDRI showing up. Here I attach is the test render image. Link to comment Share on other sites More sharing options...
Nicolai Bongard Posted November 16, 2017 Share Posted November 16, 2017 Some things to check: Is the dome light set to invisible? Have you set the apropriate mapping for the hdri? Are you sure it is the only dome light in the scene? Link to comment Share on other sites More sharing options...
gianzanare Posted November 21, 2017 Author Share Posted November 21, 2017 Thanks for your answer Nicolai, but yes I,ve checked all those parameters already and they are fine. What else could it be? Could it be that the model was exported using sketchup? Link to comment Share on other sites More sharing options...
Corey Beaulieu Posted November 21, 2017 Share Posted November 21, 2017 Are you using clipping in your camera? Link to comment Share on other sites More sharing options...
karthiksn Posted December 12, 2017 Share Posted December 12, 2017 yes i think so. he is using clipping in camera .or may be if he check invisible in light option . Link to comment Share on other sites More sharing options...
