Need help with GPU & Hybrid Render SU 2017
hafidzdin
Hi guys so i’ve just updated both my hardware & software. I’m running Vray 3.6 for SU 2017.
My problem is that it seems like Vray is not utilising my GPU. Seeing the usage when i render something, CPU is at 99% load while GPU 1 is at 1% GPU 2 is at 3% tops. I’ve deselected C++/CPU in GPU Select tool and still it wont use just the gpu.
I ran both in SLI and not in SLI, same results. Also, in asset editor’s settings. I thought you’re supposed to have hybrid render options (c++/cpu & *your gpu*) next to the GPU button. Mine says “ No option found “.
I have a huge project to render due some time next week hence the hardware upgrade. Appreciate if someone could help.
