Reflection behind glass - problem
mirakantor
Hi Mira,
Really, you need to show your material settings so we can say what to do.
Without seeing those, I'd say adjust the reflect value, leave reflective glossiness at 1.0 or turn it to .99. Also check the box (reflect on backside), as this will allow your glass to calculate reflections on the backside. If it's still not reflective enough for you, try clicking the 'L' on Fresnel reflections and turning the amount up from 1.6 to 3 or 2.5, test and see what works best.
If it still doesn't work, then right click on the object and select Object Properties, turn on 'Backface cull' and see if your objects have flipped faces. If they do then but a normals modifer on and flip the faces.
If it's still not working, please post your material settings.
Best, Tom
Hi guys,
can anyone help me, please?
I have simple issue. I dont know, how setup materials or VrayProperties if I want show reflections behind glass object on background object with Wrapper material...
many thanks for some ideas!
mira
Thank you Tom,
I attached materials settings. I dont know what is wrong. I tryed lots of combination. I dont belive it is feature of Vray :-)
Edited by mirakantor
