Sherif Massoud Posted December 3, 2017 Share Posted December 3, 2017 Hi, Please check attached 3d image, I need to know how to show edges between different walls levels behind each other and they are taking same material and (client doesn't want to change sun direction:(), I marked the part I'm talking about by red, also you can check same part in cad plan..I'm attaching the render settings as well. Thank you.. Link to comment Share on other sites More sharing options...
Nicolai Bongard Posted December 4, 2017 Share Posted December 4, 2017 You could try to add a vray edges tex to the bump slot of your wall material (or create a vraybumpmtl with it) to create rounded edges (as it would be in real life), then it should show a highlight from the sun between the walls. Link to comment Share on other sites More sharing options...
Tom Sproule Posted December 4, 2017 Share Posted December 4, 2017 Hi Sherif, Try rendering an AO pass and adding that. Here's a short tutorial on YouTube. If it doesn't do what you need, then you have to shade the walls in photoshop. Kind regards, Tom Link to comment Share on other sites More sharing options...
Sherif Massoud Posted December 6, 2017 Author Share Posted December 6, 2017 Thank you Nicolai and Tom very much for your help.. Link to comment Share on other sites More sharing options...
