Sherif Massoud Posted December 3, 2017 Share Posted December 3, 2017 Hi, Please I need help in removing bad grainy effect for white cornice in shadow area, I tried all subdivisions settings possible but no good result, the bad effect happens when I move the camera back, but when the camera is close the effect is gone:( (I tried screen and world in light cache settings and changing the samples size also but didn't rid of it!!) Thank you.. Link to comment Share on other sites More sharing options...
Tom Sproule Posted December 4, 2017 Share Posted December 4, 2017 Hi Sherif, On the GI try changing Irradience map to Brute Force. Looks like that should sort it out for you. If it's still a problem, try resetting your Render settings and then I'd render with buckets using Brute Force. It looks like it's a lighting issue to me. Best, Tom Link to comment Share on other sites More sharing options...
Sherif Massoud Posted December 6, 2017 Author Share Posted December 6, 2017 Hi Tom.. Thank you for your help, I raised the light cache settings and it worked.. Link to comment Share on other sites More sharing options...
