Dave Bond Posted December 3, 2003 Share Posted December 3, 2003 I hope noone is gonna tell me to model this stuff...hehe...so how do you fellas quickly make a believable texture that casts shadows also? I was gonna just make a diamond shape crosshatch greayscale jpg and use that...but can I just do it as easliy in Viz with the delivered stuff? I use VRAY to render with also sometimes, I am still learing about it though also. Thanks! Dave Link to comment Share on other sites More sharing options...
Sawyer Posted December 3, 2003 Share Posted December 3, 2003 I haven't tried this so if it works please let me know: Thake a brick texture and apply it to the opac map slot. Rotate 45 on the w axis and place white for the grout, black for the brick swatch. I think it would be best to have the brick be square. This is just a diamond opac map. Real chain link weaves. Link to comment Share on other sites More sharing options...
Josh1587140445 Posted December 4, 2003 Share Posted December 4, 2003 I have a chainlink fence texture that I would be willing to share. It is in .tga format, but unfortunatly it is at home so I would have to post it tomorrow. I have only used it once, but it does work pretty well. Link to comment Share on other sites More sharing options...
STRAT Posted December 4, 2003 Share Posted December 4, 2003 use the opacity map method with ray traced shadows Link to comment Share on other sites More sharing options...
smoke3dstudio Posted December 4, 2003 Share Posted December 4, 2003 I am not sure if it will work or not if we use blend material. use black/white (opacity map) as a mask map. Just put chainlink map on diffuse map for material 1 only and make it 2sides. For material 2, just make specular, diffuse and ambient to be black, opacity = 0 and leave the material to be render 1 side. If it doesn't work, I prefer to use projector light or shadow bitmap. This is to avoid long time rendering. Link to comment Share on other sites More sharing options...
IC Posted December 4, 2003 Share Posted December 4, 2003 Never used these but I tend to collect good maps when I find them just incase...... Link to comment Share on other sites More sharing options...
John Dollus Posted December 4, 2003 Share Posted December 4, 2003 Or use an opacity map, change the shadow method to area shadows and check transparent shadows under the optimizations rollout. Lots of ways to do this. Link to comment Share on other sites More sharing options...
Zortea Posted December 4, 2003 Share Posted December 4, 2003 A Few years ago I used a chainlink fence on a building, it was molded, but I don´t know how it was made... maybe I can find it on my models librery... as it is a model you don´t have to use alpha channel...(better for me as long as I don´t know hou to use it) Link to comment Share on other sites More sharing options...
