Lewis Garrison Posted January 2, 2018 Share Posted January 2, 2018 This might be a stupid question but so far I haven't found any solutions. I'm in the middle of rendering in Max and I accidentally hit the close window instead of minimize on the Frame Buffer. None of the Max or Vray controls work since its in the process of rendering. Is there a way to get the Frame Buffer back? In the past I've just waited until the render was finished then reopened the window. But there has to be a way to get it back to check the renders progress. I really don't want to wait till its finished. Link to comment Share on other sites More sharing options...
heni30 Posted January 3, 2018 Share Posted January 3, 2018 (edited) Hit Cancel. Bring up your frame buffer - your image will appear showing how much has rendered. Just use the "area" red rectangle and continue rendering. (if you're using buckets in straight lines) Edited January 3, 2018 by heni30 Link to comment Share on other sites More sharing options...
Lewis Garrison Posted January 3, 2018 Author Share Posted January 3, 2018 Thanks George! Link to comment Share on other sites More sharing options...
