Weird stains in the VraySampleRate pass
Dark Band Studio
Hello,
if you check the Vray_SampleRate pass attached there are some funny artifacts on the floor (there is a vraydisplacement modifier applied to it).
The RGB pass is quite ok but if I zoom in in some points I can see the gap between the stains.
It not depends by the bucket size because the dimension is much smaller than the stains.
What do you think is a solution to avoid that stains?????
I've seen this happen when using distributed rendering, when one machine has a different version of Vray (if I remember correctly)
it also happens when I render just with the local machine
use UNC paths for distributed rendering
All the external files (XREFscene, materials, proxies) are through the network (\\machine_name\folder\filename)
I tried to restart the local machine and render without DR and the blocky samplerate pass seems less intense but still not totally solved
The issue is SOLVED but I have no idea how I made it. I will tell you all the changes I have done since the problem came out till now.
The blocky area in the VRAYsaplerate pass was effecting just the floor. Due a design decision I reduced the tiling size in the floor and tweaked a bit the UVWmap to a different size.
I restarted the machine and the the issue has gone and the render timing seems a bit quicker.
TECHNOLOGY MISTERY
thanks again for your help!!!!
