HP Z800 best Nvidia settings vor Rhino&Vray&Quadro 5000? Upgrade Quadro or GTX?
Hi,
I am working in architectural visualisation, predominantly I create spherical 360 degree still images. Picture size typically 12000 x 10000 pixels.
Rarely I render movies (yet).
So far no gaming at all. Still want to test game engines for rendering in Arch Viz (not for gaming though.
Apart from that, I do work a lot with Affinity Photo on very large files with hundreds of layers.
To do this I use Vray 3.6 for Rhino 5.0.
Vray can now handle the combined use of CPU & GPU via Cuda.
Still, when doing this the images turn out grainy/noisy despite the denoiser beeing on.
CPU alone rendering works fine and gives good results, but is slow, that why I want the combined power.
My current graphics card Quadro 5000 never shows much usage in the Nvidia GPU utilisation graph when rendering but its memory gets fully used and I get an CUDA error 2 : unable to allocate enough memory to perform the requested operation (out-of-mem).
I suspect a settings error.
Neither Rhino or Vray are listed in the "3D Settings" field of the Nvidia control panel and I wonder if someone can recommend the best settings to choose.
At the moment I use the the 3D App-Visual Simulation Profile with:
-Open GL Overlay switched on
-Power management to Max
-Tripple buffering on
-Vertical sync on
In the following the spec of the machine.
An upgrade to a Quadro M5000 and 72GB of RAM is planned.
My machine has the following spec:
  • HP Z800
  • 2x Xeon X5650@2.67GHz
  • 24GB RAM (soon 72GB)
  • Quadro 5000 (soon Quadro M5000) Driver 377.83
  • Windows 10Pro 64Bit latest release
  • Rhino Version 5 SR14 64-bit (5.14.522.8390, 05/22/2017)
  • Vray 3.6 for Rhino latest release
I'd really appreciate if someone could suggest the best settings for the current graphic card.
I am less after on screen display quality but much more after final result quality.
Apart from that should I get the Quadro M5000 or better a GTX for my work? Suggestions?
The Quadro M5000 has 8GB GPU RAM, the current Quadro 5000 is old and has 2.5GB.
Thanks so much,
Franzi
