3d Max 2018 - buggy?
Yuli Laz
  • 3 weeks later...
Max 2018 is pretty stable for me. And there are already 4 SP's out for Max 2018. So i do not understand the statement that there are not many out for Max 2018. I' m still on W7 though, and i got the impression that W10 produces problems for some users, especially viewport related
I 've read about a significant amount of people got viewport slowdowns because of some defective UI configs.
So at first i would try to reset your ribbon config to defaults ( RMB menu on the ribbon->Ribbon Configuration->Reset Ribbon to default ) and restart 3ds Max. This solved the slowdowns for some people. If it does not work for you, i would close Max, rename my 3ds Max ENU folder in the user directoy to something else ( just for backup purposes ) and start Max again and see whether the slowdown still exists
If no, you got the root of the problem and it will be best to simply reconfigure your 3ds Max to your preferences from the ground up
