linussjoholm Posted February 25, 2018 Share Posted February 25, 2018 Hi! I have some issues when i use the HDRI (one of Peter Guthries) in 3ds max and Corona. The HDRI is too overexposed in the viewport and I have lowered the output amount but that only affects the render and not the hdri in the viewport. When I use vray you can lower the brightness of the hdri in the processing tab and it affects the hdri in the viewport but in Corona I have no idea . Any help would be appreciated! Thanks in advance. Link to comment Share on other sites More sharing options...
serkanh Posted January 22, 2019 Share Posted January 22, 2019 Hi! I have some issues when i use the HDRI (one of Peter Guthries) in 3ds max and Corona. The HDRI is too overexposed in the viewport and I have lowered the output amount but that only affects the render and not the hdri in the viewport. When I use vray you can lower the brightness of the hdri in the processing tab and it affects the hdri in the viewport but in Corona I have no idea . Any help would be appreciated! Thanks in advance. you can check this video cheers! 1 Link to comment Share on other sites More sharing options...
James Vella Posted January 22, 2019 Share Posted January 22, 2019 Serkan he means in viewport, not IR/Render. I have the same issue with some HDRIs, Im guessing you are just trying to rotate it so you have the sun in the direction you want, you can temporarily switch on the Exposure Control in Environment & Effects and drop the EVs until its visible Link to comment Share on other sites More sharing options...
James Vella Posted January 23, 2019 Share Posted January 23, 2019 I forgot about this thread where Juraj explains how he achieves the viewport view with Corona using the Vray HDRI loader. https://corona-renderer.com/forum/index.php?topic=10190.30 "I am using relative EVs exposure (just artistically, not exact match to real world cameras), so I adjust Peter's HDRi into 0.01-0.1 multiplier (I am using VrayHDRi loader) so I can see them exactly as other industry-standard HDRis :- ). Using HDRi with low multiplier and high exposure or high multiplier and low exposure is ultimately the very same result. But having HDRi base exposure matching real-life exposure makes it easier to match to artificial light fixtures." Link to comment Share on other sites More sharing options...
designluxurious Posted May 23, 2019 Share Posted May 23, 2019 That right Link to comment Share on other sites More sharing options...
Stephen Thomas Posted July 24, 2019 Share Posted July 24, 2019 One post-processing trick I've been using a lot recently that might help you is to save out to 32-bit HDR format, then lower bit depth in Photoshop to 16-bit and choose the 'Highlight Compression' option. After that you can use levels or curves adjustments to bring back contrast in your image. This also works well for bringing some colour back into blown out interior lights. Link to comment Share on other sites More sharing options...
