omshanmukha Posted March 8, 2018 Share Posted March 8, 2018 Anybody know about this bug and how to fix it! When I apply a default material to the geometry its showing in the viewport but on adding a bitmap in the diffuse slot makes the geometry disappear from the viewport but is showing in the wifeframe mode and while rendering! Please do help me out anyone! Link to comment Share on other sites More sharing options...
Chris Harris Posted March 8, 2018 Share Posted March 8, 2018 Not sure if this is your issue, but occasionally out of the blue I'll have some geometry being "Display as Box" in the Object Properties - Display properties checked...and I know I never clicked it. Check that out. Link to comment Share on other sites More sharing options...
omshanmukha Posted March 9, 2018 Author Share Posted March 9, 2018 I checked it but that option in object properties is not selected, this only happens after I apply the bitmap in the diffuse slot! If the diffuse map is disabled then the geometry is visible again in the viewport! while in the object properties the "display as box" option is not selected even when the bitmap is added in the diffuse slot and the material is applied to the object! Link to comment Share on other sites More sharing options...
James Vella Posted March 9, 2018 Share Posted March 9, 2018 try it with a jpg, if it works it could be the alpha in the image if your using another format, you will have to tell the diffuse map to ignore the alpha. Link to comment Share on other sites More sharing options...
