prestyprasad Posted March 16, 2018 Share Posted March 16, 2018 Hai .i have a problem during vray render.i got the output but image is with black pixels on some objects .why it is like that .how to resolve it .pls help Link to comment Share on other sites More sharing options...
Chris MacDonald Posted March 16, 2018 Share Posted March 16, 2018 (edited) It's because: 1) you're using a sharpening filter - this is what causes the black ringing and... 2) the (floating point) contrast between light/dark is too great for the antialiasing sampler to resolve. Your options are one of or a combination of: A) Render at higher resolution. The problem will still be there, but will effectively be reduced in size. B) Use a softer AA filter (sharp filters look shit anyway) C) Clamp the output to something low enough for the AA filter to deal with. D) Turn on sub-pixel mapping - Generally clears up the issue, but at a cost of image quality (depends if you notice it or not). E) Use max ray intensity (may/may not work) - akin to clamping output, but not quite. F) Use lens effects (glare/bloom) to hide the issue. I've highlighted what I'd do, personally. Edited March 16, 2018 by Macker Link to comment Share on other sites More sharing options...
prestyprasad Posted March 16, 2018 Author Share Posted March 16, 2018 I use catmull rom filter Link to comment Share on other sites More sharing options...
Chris MacDonald Posted March 19, 2018 Share Posted March 19, 2018 Why do you use catmull rom? Because a tutorial told you to? Link to comment Share on other sites More sharing options...
