Ricardo Oliveira Posted April 23, 2018 Share Posted April 23, 2018 (edited) V-Ray 3.4 for SketchUp. I'm having an issue with the noise legacy bump that I'm using for a water pool... It's not reflecting the blinds properly... It renders normally with no bump... Another problem is with the specular on the pool ladder... it's all messed up. Need help! Edited April 23, 2018 by ricardooliveira1 Link to comment Share on other sites More sharing options...
Tom Sproule Posted May 6, 2018 Share Posted May 6, 2018 With the bump it should look like your render, as the water is now pointint in other directions and so reflecting different areas of the room. You could try lowering the amount of bump if you like, I would suspect your bump amount is too high. Link to comment Share on other sites More sharing options...
