CEJ1976 Posted May 10, 2018 Share Posted May 10, 2018 Hi, I am experiencing some very strange results when trying to use the Vraylightselect render element. I have used this render element many times over the years, and it has proven to be a very useful way to adjust lights in post-production. However, I am experiencing some extremely random results with it at the moment. Please see below a series of screen grabs of the Vraylightselect results from within the frame buffer. As you can see, the light results are not as they should be, they either seem to render as white, or very burnt out and blotchy. No 2 is about the most accurate (it’s a HDRI light), but then the same light source from a different camera in the same scene results completely differently – see No 1. Does anyone have any idea what is happening? Normally these passes render out beautifully and are great for compositing. Thank you. Link to comment Share on other sites More sharing options...
bulicn Posted May 14, 2018 Share Posted May 14, 2018 As far as I know, IM is not working as it should with Vraylightselect (v3.6), only when using Brute force. They will fix that in the future release. Not sure if that is the problem here though... Link to comment Share on other sites More sharing options...
