romanm Posted June 17, 2018 Share Posted June 17, 2018 Hello, I want to learn how to set camera properly for still image. I know nothing about that. I would like to know how to combine Film width, focal lenght and more. It can be for interior design, it can be universal, I will take everything. I searched on youtube and vimeo and I can't find any tutorial or exercise for that. I appreciate that. Link to comment Share on other sites More sharing options...
Tom Sproule Posted July 7, 2018 Share Posted July 7, 2018 Hi, The reason is there is no camera setting which works perfectly all the time and we all have a different work flow. What you need to look at is camera settings for photography and then copy those and put those in 3DS Max and V-Ray. Really you are looking at 3 settings, which are all on your Physical Camera: 1. Your aperture f/ which by default is set at 8. See what is suggested based on your scene in a professional photographer forum. 2. Shutter settings - by default it's on degrees. I normally use 1/seconds - set it to 20 if you want it to be 1/20th of a second. Again, look at pro photography forums. 3. Exposure - make sure you install exposure control. You will need to select either EV or ISO and then set the correct amount. I hope this helps. Best, Tom Link to comment Share on other sites More sharing options...
romanm Posted July 8, 2018 Author Share Posted July 8, 2018 I know that everybody has diferent workflow. But your advice is useful for me. So don't look for 3DS max camera setting tutorials and tips but search for photographers camera setting ;-) Thanks Link to comment Share on other sites More sharing options...
