I have render of tea pot and background fro the environment map for the reflections
jonathan Evans
  • 2 weeks later...
Hi,
I'm not 100% sure on what you are trying to do, but you could remove it from the environment slot. Then open the render setup dialoge and open the Environment roll out and then turn on Reflection/refraction environment and place it in there.
That should achieve what you've asked for so far.
I know you are not using HDRI's but this tutorial is really about the environment rollout in the render dialogue and should give you more information:
If it's rendering too dark in the reflection then put it into an output map and increase the RGB value, that should pump it up.
Best, Tom
