komyali Posted June 26, 2018 Share Posted June 26, 2018 hello guys, I need help on this one, till now I used simple UVW mapping and unwrap, but now I am not sure how to make effect? So i want on this on driveway to put paving stone but not sure how to get this effect? Substance painter ?Quixel? Or there is simple way in 3ds max or vray to do this? I want 2 types of stone to go on edge of my driveway and 3. type to be inside(doesnt have to follow anything just planar uvw) tnx Link to comment Share on other sites More sharing options...
komyali Posted June 26, 2018 Author Share Posted June 26, 2018 ok my brain sometimes doesnt work well... insert mesh how much you want, then straighten in UVWunwarp, done in 2 min Link to comment Share on other sites More sharing options...
Francisco Penaloza Posted June 28, 2018 Share Posted June 28, 2018 You could also use the path option in the UVWunwrap modifier. select the edges of your geometry and create a spline from that selection, then use that path to 'guide' your mapping for the exterior, then regular mapping for the interior. Now if it is a close-up shot I may build it with Railcloner. Many ways to approach this actually. Link to comment Share on other sites More sharing options...
